High Low Beam column mount switch?
Does anyone know if the combination turn signal/hi low beam switch off a newer model will fit any of the aftermarket columns? I'd like the hi/low beam to be on the turn signal switch but cant find a column in the salvage yard that is simple and clean like a 79 Camaro column.
Thanks, Dave |
I always just use a floor mount type ... like from a GM vehicle from the late 60's ... easy to wire, easy to use and easy to mount. Also easy to replace if you ever need to. All the ones I have ever seen that mount on the column are large, bulky and not very attractive. I always use a GM van tilt column and they are small and do not leave a lot of room for a BIG ole turn signal switch. If you really want a turn signal/high - low beam changer on the column ... I suggest looking at a later GM van tilt column. They are plentiful in supply and cheap to buy ... no one much wants them because of the bulk . . |
Thanks Duece. I guess I'll just stick with the floor mount like you. I just thought it would be nice to have everything I can on the column.
Dave |
I don't know Deuce, I think one of those first switches you showed would look a little funny duct taped to the steering column...LOL
Thanks guys for the help.
Dave |
| Recent General Rodding Tech posts with photos |
| neutral safety switch wiring ford column to 700R4 | 49willard | Electrical | 7 | 12-01-2007 05:27 PM |
| Steering Column Install | Quarter Flash | Suspension - Brakes - Steering | 3 | 05-10-2007 11:36 AM |
| gm tilt column ignition switch | mikoman | Electrical | 2 | 10-24-2006 06:38 PM |
| low rpm high torque | bluetruck | Hotrodding Basics | 9 | 07-09-2004 11:44 PM |
| nitrous with high or low compression? | brainsboy | Engine | 5 | 03-19-2004 05:23 PM |
