Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - High Low Beam column mount switch?
Old 01-12-2008, 02:54 PM
Deuce Deuce is offline
I always just use a floor mount type ... like from a GM vehicle from the late 60's ... easy to wire, easy to use and easy to mount.
Also easy to replace if you ever need to. All the ones I have ever seen that mount on the column are large, bulky and not very attractive.
I always use a GM van tilt column and they are small and do not leave a lot of room for a BIG ole turn signal switch.
If you really want a turn signal/high - low beam changer on the column ... I suggest looking at a later GM van tilt column.
They are plentiful in supply and cheap to buy ... no one much wants them because of the bulk .
