Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - High Low Beam column mount switch?
Old 01-13-2008, 10:16 PM
1969NovaSS's Avatar
1969NovaSS 1969NovaSS is offline
turbo lag......yeeeeehaaaaaaw
I recently rewired a 58 apache and the guy wanted to use the multifunction switch from a 79 camaro. The high beam switch had the same connector that would have gone to the floor mounted one. The big connector has 2 extra wires that arent needed. the connector is also a a different size so take one from the donor car and just pull the pins out.
