Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - high nickel blocks ?
Old 08-31-2005, 03:27 PM
jesse01's Avatar
jesse01 jesse01 is offline
mini me
the 010 ( the 3 digits of the casting #) blocks have 2% more nickel & 1% more tin
also like braceteer stated the dipstick wii be on the driver's side
i know it's hard to see the casting #'s while the engine is still in the car. so if you have one apart, right behind the timing chain cover and timing chain(on the 010 blocks i don't know about the others) there will be numbers stamped into the block. they will say 020 & 010. which means 2% more nickel & 1% more tin
J
