High oil consumption after intake and valve cover change - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2008, 04:14 PM
junkyardjeff's Avatar
I put a very low mile 302 in my 65 custom 500 that did not use a drop of oil in between oil changes and after I changed the intake and valve covers it started drinking oil,I first suspected the valve covers and put the originals back on and it only slowed the oil loss slightly. I checked the intake bolts and most were loose even though I torqued them to edelbrocks specs,along with the intake I bought a installation kit that came with bolts and should of suspected inferior quality when one bolt broke so I removed all the suspect bolts and replaced them with the originals so I will see what happens now. DO NOT and I mean DO NOT use Mr gasket intake bolts as the quality is not good and I hope that was the problem as i dont want it to be a porus intake. Jeff
Old 05-17-2008, 05:07 PM
T-bucket23's Avatar
Wiki Edits: 26
You valve covers are probably allowing your PCV to suck up oil. A lot of the cheap ones do not have baffles
Chet
Old 05-17-2008, 05:23 PM
It sounds like your intake couldn't be sufficiently tightened and it was drawing oil from the valley.
Bolts and fittings are a real head ache any more with so much indo-asian junk out there. I ran into thread pitch problem a few weeks ago with carb studs from Holley, I don't know what they were made for but USS/SAE or any metric I know sure wasn't it.
Bogie
Old 05-17-2008, 06:36 PM
Now that I tightened the intake the motor starts better when cold,I am going to run it a bit tomorrow and see if it loses any oil. Jeff
Old 05-17-2008, 06:48 PM
I had the same problem with oil consumption after I changed intake manifolds. I didn't have a torque wrench, but I figured it would be ok if I just tightened it down real good. It wasn't, and I had oil all over the place. Finally took it to my dad's and used his torque wrench to tighten it down the rest of the way, and it hasn't used any oil since.
Old 05-17-2008, 10:40 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
http://www.crankshaftcoalition.com/w...ak%2C_internal
Correct way to set valves on sbc w/ solid flat tappit camshaft? Joshua Lee Engine 17 02-09-2011 05:55 PM
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
