High Oil Pressure Concern - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2008, 07:18 PM
i have a 1988 chevy k5 blazer with a chevy 350 that i built in it. the engine is bored .030 over, has a mild cam, and a high volume oil pump. the motor has about 1000 miles on it and sat for about 6 months at times without being run. recently it started smoking(oil smoke) out of the right side of the motor only. i changed the oil and for some reason added a type of restore product to the oil to try to remedy the smoking. after this, the oil pressure is about 60 at idle and pegs my mechanical guage at 100 under throttle. this worries me a bit. any info would be much appreciated.
Old 10-26-2008, 07:39 PM
DoubleVision's Avatar
You don`t need a high volume oil pump if the clearences are right. they only cost more power to drive. It`s likely smoking due to sitting. Run it and it`ll likely stop.
Old 10-27-2008, 12:10 PM
What type of restore product. The bypass valve should open and vent excess pressure, if you're getting over 70-75 psi, I'd be concerned that either the bypass is jammed in a closed position or the product you put in is so thick it can't vent quickly enough to where the valve has any authority over system pressure anymore.
An engine that's sat for 6 months has had plenty of time for corrosion to go to work on the cylinder walls and rings. It's likely that there is damage to one or more of the bores. Auto engines are shut down by killing the electrical ignition. This leaves fueled cylinders and cylinders with combustion products in them, unless treated for extended shut down with a top oil product it's highly likely that corrosion has occurred or gums and varnishes formed gluing the rings in place. This is not even to mention what a dry start up can do, especially if you helped it start with either.
Bogie
Old 10-27-2008, 09:56 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
First change the oil, and don't put goop in there.
high volume oil pump question jstaten Engine 4 01-15-2006 11:56 PM
No Oil Pressure!! MartyMart9@aol.com Engine 43 04-26-2005 06:37 AM
Oil pressure at high rpm Tiresmoke7 Engine 6 04-09-2005 01:19 PM
Low idle oil pressure chuckellison Engine 4 03-03-2003 07:20 AM
