-   -   High performance (http://www.hotrodders.com/forum/high-performance-2694.html)
sidtracy 06-04-2002 02:44 AM
High performance
I recently purchased a 2002 Vette, 5.7L, 350 hp. How can I increase the performance (hp) without tearing the engine apart?
Chevydude 06-04-2002 03:40 AM
Leave it along. You already have a fine machine!!
mustang66maniac 06-04-2002 03:07 PM
Stick with the easy bolt on stuff, like headers, mufflers, throttle body, cold air induction with k&n. A good combo should give you about 30 horses
F-1Rodder 06-05-2002 10:06 AM
As you know the motor in your car is as well engineered as Chevy thought was practical. However there are a couple of things you can do. The computer chip can be re-programmed for different performance characteristics. I don't personally know much about this because I am more of a retro rodder type, but know that you can run a laptop program to increase performance.
The other thing you can do is add a nitrous oxide system. This can give you huge gains in power....I mean you could double your HP.
But not all the gains are in the motor. You can make suspension and tire modifications that make it more fun and faster to drive in the twisties etc. Join a Vette club. This is where you learn the tricks for later model cars such as your.
agb1758 06-05-2002 08:43 PM
One thing you have to remember about GMs after 1996, you have to have the chip reprogramed in the car, you can boost it up only one time, then return it to normal once, after that you will have to get a new computer. They will not accept the performance chips like earlier GM models would.
