Hi everyone, back to the site after a few years so, sorry if I posted in the wrong area, or asked a question thats been done before.
I trying to learn as much as I can about high Powered Ignition Systems, and are just a bit unsure on a few things. I have been told so many different storeys and things about High Powered Coils and Leads, I'm a bit lost!
I spoke to a guy at Bosch Tech help a few years ago that seemed helpful.but I thought I would see if someone there could offer anymore help.
I have a 1982 302 Ford Cleveland engine that has the standard Bosch Electronic Ignition System.
I seem to be getting told so many different things about what type of Coil and leads I should be running. I'm unsure if by going for the big Yellow Accel Super Coil there would be much difference or a MSD or Mallory High Powered Coil. I was also told once that the MSD Blaster 2 and 3 are just normal rated coils marketed to be something special.
To add to this, I was told by once by Bosch that with Electronic Ignition, the amount of Power a Bosch Transformer Electronic Ignition Coil will throw out is the same as any high powered performance coil, and there for there is no need to seek a so called high powered coil.
He went on to say that the MAX that the High Ten Leads can handle and pass through, is what the Bosch Coils put out anyway and that a Street engine would not require anymore than that, unless I went to a Multi Spark System and so on.
So I am wondering, 1 what coil's would you guy's recommend, and 2 would you say that by adding a Super Coil for eg there would be any major gains?.
Thanks so much for any help you can offer.
Kind regards,
Francis.
Kind regards,
Francis.
