high presure fuel pump and fuel injectors ( 300 psi) - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2007, 05:10 PM
For my liqued propane injection project I'm looking for some parts.
I need a high presure fuel pump 300 psi more is better.
A belt driven pump will also be fine as I could start the engine on gas and switch over to propane after startup.
Also I need fuel injectors that can handle the high presure an have enough flow
Where can I find these parts????
Remco
Old 08-27-2007, 05:37 PM
300 psi is fighter jet turbine engine territory.
Old 08-27-2007, 05:58 PM
ya u defiantly do not need 300 psi.
Old 08-27-2007, 07:11 PM
Wiki Edits: 31
yea, 300 psi is crazy, but if you must. there is 1 aeromotive fuel pump that can pump up to 500 psi I think, but it's gonna set you back over $600
Old 08-27-2007, 07:36 PM
Did you take a look at either of the 2 links that I posted in your other thread?
This thread comes up near the top with a search for "propane"
http://www.eng-tips.com/viewthread.c...=129931&page=8
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
!!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!! islandman Engine 3 03-17-2007 03:36 PM
93 Suburban fuel pump sabino56 Engine 8 09-10-2005 02:54 PM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
