Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - high solid clear
Old 01-07-2006, 05:32 AM
mrcleanr6's Avatar
mrcleanr6 mrcleanr6 is offline
high solids means that percentage of resin compared to solvent content is higher. basically its thicker and more stays on the surface without evaporating away. usually you need atleast a 1.4 tip to spray it depending on how high the solids are.
