Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - high speed sander discs
Old 02-05-2009, 09:12 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
If you are using a high speed sander, you need a disc with a hole in the center, Self adhesive discs are for patternless DA sanders.
If you are trying to get them to stick to a DA pad, try cleaning the backing pad, and get all the remnants of old paper off. The vinyl cover needs to be smooth if you want self adhesive discs to stick at all. The tool sale discs you got probably need to have the sticky stuff reapplied, so follow Dinger's advice.
Don't put vinyl top adhesive on your DA backing pad, unless you want to replace it along with your sandpaper.
Later, mikey
BE different....ACT normal.
