high squeal after installing sunshell, shaft, and ring gear assembly - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2011, 09:16 AM
old yukon's Avatar
I have installed all the components in the lower half of the 4L60e transmission (up to ring gear assembly).
With all new bushings and bearings I went to test the rotation of the sunshell and ring gear assembly, and i have this loud squeal sound when turning the sunshell. but no real noise when turning the ring gear assembly.
What could it be, this doesn't seem normal ? (CLICK IMAGE TO PLAY VIDEO CLIP TO HEAR THE SOUND)
Old 04-27-2011, 10:06 AM
tnsmith10's Avatar
when will it rain???
thats the sprag. thats normal
Old 04-27-2011, 10:11 AM
Last journal entry: Some More Roll Cage Fabrication
X2 normal noise
Glad to see it going together. Bout time! J/K
Old 04-27-2011, 10:31 AM
old yukon's Avatar
Man If that's normal, for a precision piece of automotive engineering then I have to redefine my gut intuition.
You guys are the pro's compared to me so i kind of have to trust you on this one ;(.
Deep down inside I feel this thing is going to squeal down the road, wake up all the locals and get me chased by the task force for disturbing the peace.
Hay but no problems!, with my beefed up 4L60e they will eat my dust..... QUEEEEEEELLL !!!!!, RRRRRRRRRRRRrrr.. WOOSH... !!!!
Old 04-27-2011, 10:52 AM
I can't play the video, but sprags DO tend to be noisy on assembly. Does the noise change when changing direction of rotation? If so, sprag - normal.
Old 04-27-2011, 10:59 AM
old yukon's Avatar
http://s1115.photobucket.com/albums/...=Video0029.mp4
Old 04-27-2011, 11:10 PM
squeal
is that a o.e.m. shell of aftermarket ?
Problem on the input housing and shaft assembly?? old yukon Transmission - Rearend 1 02-28-2011 07:36 PM
High pitch squeal noise after head repalcement in Chev 350 twistmas Engine 4 03-19-2010 05:17 PM
Help installing new ring & pinion bud34pick Transmission - Rearend 3 04-29-2008 06:48 PM
T5 assembly question on input shaft. Huskinhano Transmission - Rearend 0 01-13-2004 05:10 PM
installing power brake assembly on model a frame straycat60 Suspension - Brakes - Steering 1 02-12-2003 04:44 AM
