high static compression 283 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2008, 05:35 PM
what is the best way to get about 13:1 static comp. with small chamber heads that will breath? maybe 15:1 for e85
Old 04-29-2008, 12:05 AM
327NUT's Avatar
Obviously this is not a street machine with that quest for 13-15:1 comp. Tell us a little more about the engine and application.
Old 04-30-2008, 09:47 PM
Flipper_1938's Avatar
It's gonna be hard to get that high of compression on a small cubic inch motor with 23* heads.
327NUT- Alcohol likes/needs the compression
Old 05-01-2008, 01:44 AM
327NUT's Avatar
...............or better yet, why don't you just ignore the members that are waisting their time trying to answer your question?????????
To High Compression For A Turbo Setup-what Can I Do??? hannes_slanec Engine 52 12-29-2007 01:57 PM
Original high compression engines lluciano77 Engine 15 11-15-2003 11:02 PM
high performance 283 steve Engine 2 06-22-2003 03:25 PM
What ever happened to high compression? 54Guy Engine 14 05-15-2002 06:17 AM
Alum.heads & HIGH compression plysat Engine 6 03-12-2002 03:59 PM
