high temp activator in lower temps for clear - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2010, 05:07 PM
I usually use the high temp activator because I heard it can help with solvent pop, keeping the clear open longer to let the solvents out. Does this make sense as long as it's not to the extreme? I'm mainly talking about 85 degree activator when the temp is 70 to 80 degrees.
Old 05-25-2010, 05:31 PM
Old Fool's Avatar
I always use slow activator and reducer above 70f.
Old 05-25-2010, 06:54 PM
Me too, specially on completes.
Old 05-25-2010, 07:06 PM
Are you guys using it for flow-out reasons or some other reason?
Old 05-25-2010, 07:17 PM
Yes mainly, slow should lay down nicer, more time allowed to flow, better gloss. Plus I like to have as much time as possible. Also will allow the paint to stay open longer for solvents to escape. Always better to go on the slow side for the temp as opposed to too fast, with one exception shooting a flattened finish, a slower reducer may make the resulting gloss level glossier then if a fast reducer were used.
Old 05-25-2010, 07:26 PM
That makes sense, thanks.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Can a lower temp thermostat hurt my engine? CCR Engine 15 09-15-2007 06:58 PM
Lower temp thermostat? draft Engine 4 11-14-2004 05:04 AM
Emissions HELP cutsupreme Engine 33 12-27-2003 08:22 AM
Trans cooler = lower engine temp JUSTINH Engine 1 06-06-2003 01:40 PM
