High temp coatings - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2011, 11:50 AM
Last journal entry: Body work
High temp coatings
Any of you have experience with high temp coatings with turbo applications?
I am to the point of coating the headers, turbine housings and the rest of the exhaust for the twin turbo LT1 I'm using in my Rambler project.
I've heard the aluminum colored coatings don't hold up on the headers and the turbine housings.
They have a black coating that is good to 2000 degrees and that is what I will probably use on the headers and turbine housings. Then, the aluminum colored coating on the rest of the exhaust.
I would also like to coat the mid section of the turbos with something so they don't rust but not sure what to use.
Merry Christmas.
Ed
High temp or Bad gauge? Pre-Tuner Engine 3 07-21-2011 07:49 AM
High temp paint fullthrottle Hot Rod Art 4 03-26-2007 03:11 AM
High Temp Paint lonerangerusa Engine 4 02-18-2006 09:26 AM
temp.gauge high & low john69 Engine 3 12-02-2002 07:46 PM
