high temp enamel paint on aluminum? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2012, 06:06 PM
Does enamel paint (on the outside of course) raise the internal temp of a transmission?
Or are there any other reasons that his would be bad?
Old 08-10-2012, 06:33 PM
abba
yes, painting the bare aluminum case will hold the heat in.
it would be bad because tranny fluid eats paint.
have a nice day!
Old 08-10-2012, 09:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You will see no difference on temps with a light coat of paint on the transmission.
The Following User Says Thank You to Crosley For This Useful Post:
abbazabba (08-10-2012)
Old 08-10-2012, 10:53 PM
I think I will leave the paint. A large trans cooler and some synthetic fluid should negate any increased temps caused by the paint.
Thanks for the input.
Old 08-10-2012, 11:57 PM
It won't matter. This isn't the technical explanation but you'll get the idea.
A specified material will only move heat through and away or into something else at a certain rate. Some grade of steel will allow heat to travel through it at a different rate then say, aluminum. You can get the technical explanation on heat transfer and coefficients from a physics forum.
Bottom line-A light coat of engine style paint won't slow it down.
Notice that I answered without using the terms conduct, radiate...
The Following User Says Thank You to Rineholio For This Useful Post:
abbazabba (08-12-2012)
Old 08-11-2012, 07:57 AM
pricesgarages's Avatar
i paint all my units with black engine paint or wheel paint hadnt had any negitive results from it
The Following User Says Thank You to pricesgarages For This Useful Post:
aluminum, enamel, paint
Engine paint, high temp paint, Powerder coating??? zbhover Body - Exterior 18 06-01-2011 08:16 PM
High temp paint fullthrottle Hot Rod Art 4 03-26-2007 04:11 AM
High Temp Engine Paint for use in spray guns? kuhn-77 Body - Exterior 3 01-12-2007 02:01 PM
High Temp Paint lonerangerusa Engine 4 02-18-2006 10:26 AM
high temp paint or powder coating headders??? 1941 studebaker Transmission - Rearend 3 12-14-2002 09:42 PM
