High Torque mini starter
I'm wiring my 59 chevy apache with a painless kit. I have a Chevrolet high torque mini starter. I attached the battery positive to the top post of the solenoid along with a 8 guage hot wire to the maxi fuse. I then attached the purple or start wire to the spade terminal on the solenoid. There is a bottom post with nothing attached. What is this for?
Thanks for your help. |
Doc here,
Well, not knowing what starter you have .. MY BEST GUESS would be that it is an "R" terminal for the secondary ignition for a points type ignition..not used for HEI or CDS.. Assuming it is a smaller terminal AND the starter motor IS hooked up to the solenoid. Can you snap a photo and post it here? that would help. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
The bottom post is the same size as the top post. The headers are in the way so I can't get in there to see or read. I guess it makes too much sense to look at it closely before I installed it. Where does the neutral safety switch from the tranny attach?
Thanks |
Thank you all!
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 10:22 AM |
| torque converter banging??? Flywheel or tranny?? | boneyard Buick | Engine | 5 | 09-04-2006 03:07 AM |
| Starter Help - 69 Z-28 | daveh | Electrical | 2 | 08-22-2004 05:08 PM |
| Starter Help - 69 Z-28 | daveh | Engine | 1 | 08-21-2004 10:41 PM |
| High torque starter? | killerformula | Engine | 16 | 12-17-2003 06:20 PM |
