High torque mini starter noisey - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2005, 07:11 AM
I installed a high torque mini starter on my 350 and even with about 1/8 inch of shims it still sounds as if it is binding on the fly wheel. This is my first attempt at using a proform 220 should it sound like that or should I continue shimming it?
Old 09-07-2005, 07:48 AM
you don't need 1/8" of shims, you need 1/8" space between the bottom of the ring gear and the top of the starter teeth. You use the shims to adjust that gap to 1/8".......
Old 09-08-2005, 10:44 AM
Bad Rat 414's Avatar
www.bigblock67chevelle.co m
Make sure you have the correct starter for your flexplate or flywheel. The number of teeth can vary.
Chevy starter problems downonthebayou67 Engine 10 03-29-2010 12:55 PM
chevy 350 starter problems!!! zipfactor Engine 19 09-24-2008 08:01 AM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
What Can I Really Expect From a High Stall Torque Converter ? white66coupe Transmission - Rearend 3 05-25-2003 05:21 AM
