Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - high torque starter
Old 07-22-2012, 09:41 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
I use the same starter that Warren johnson uses,or used in the past.Its about full size though.I bought it from lukovich engines,so far trouble free for 7 years. Check your wires.Use welding cable if the battery has been relocated.Super high compression and a lot of lead timing can be bypassed with a kill switch or ignition retard for start up.
