Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - High Torque Starter Questions
Old 01-09-2011, 06:31 PM
tnovot's Avatar
tnovot tnovot is offline
Originally Posted by 1975yellowC3
Thanks guys.
sjkonyndyk...thanks for the part number
I think I am going to get the battery checked and then make sure I have a good ground. I have read on here people having problems with starters doing similar things with insufficient grounding.
If that doesn't work....off to Adv. Auto to get a new starter!
Good move on checking grounds - especially if you are indeed talkking about a C3. As you probably already know, they seem to frequently have ground problems.
If you are not already aware, corvetteforum.com has a C3 section.
Terry
