-   -   High Torque Starter Questions (http://www.hotrodders.com/forum/high-torque-starter-questions-190439.html)
1975yellowC3 01-09-2011 02:19 PM
I just started my brand new 383 a few minutes ago. It actually started... :D (1st motor I have put together and I was scared to death to hit the starter!!)
It died shortly after it started a couple of times as my carb isn't quite setup right. Problem is that my starter just won't turn the thing over after it has run a little. My starter is just the run of the mill Adv. Auto Parts starter. My engine has 9.6:1 compression. I also unhooked the power to dizzy to make sure I didn't have timing advanced to far. This resulted in the same thing....barely turning motor over.
1. Does my starter just not have enough umph to start this thing?
2. If I get a high torque starter, can I just mount it up, plug it in, and go?
I don't understand these high torque starters. Does the high torque starter just have gear reduction to give it more torque, which turns the motor over a little slower. Seems like the only other way for high torque would require more current draw?
68NovaSS 01-09-2011 02:26 PM
They are plug n go, and gear reduction is their method. It doesn't result in slower cranking, it spins my 383 blower motor fast, so I assume more windings. I've hear them spin 13 to 14:1 race motors just as fast.
1975yellowC3 01-09-2011 02:48 PM
Thanks 68.
I have read some other posts about starter problems, and now I am wondering if something else is the problem??
I have the 168 tooth flywheel....should the standard starter be able to turn this motor over?
68NovaSS 01-09-2011 03:34 PM
At 9.6:1 I'd say it should do the job if it's a quality starter. Being a new engine, probably tight, not broken in, if on the hot side, I could see it being sluggish, especially if it's nestled behind headers.
sjkonyndyk 01-09-2011 04:25 PM
buy a starter from autozone or advance ask them nicely to warranty yor current unit against the new delphi starter for a
98' Chevy s10 blazer has a 168 flywheel and a staggered pattern its factory high torque and light weight.
Part number should be 96210 from advance
1975yellowC3 01-09-2011 05:35 PM
Thanks guys.
sjkonyndyk...thanks for the part number :thumbup:
I think I am going to get the battery checked and then make sure I have a good ground. I have read on here people having problems with starters doing similar things with insufficient grounding.
If that doesn't work....off to Adv. Auto to get a new starter!
richard stewart 3rd 01-09-2011 06:04 PM
Hi,
GM has 2 starters for you car, one is regular & the other is a high torque, you can tell the difference by looking at the end of the solenoid, the HT will have an extension on the screw at the bottom of sol. the regular starter the screw will be about flush with the sol. If yours is the regular type exchange it for the GM HT, they should be about the same price as the regular starter.
Rich
mud.man.rj 01-09-2011 06:10 PM
hi torque
The high torque starter is only about half the size too, nice for header clearance and the gear red really helps them spin up faster.
tnovot 01-09-2011 06:31 PM
Originally Posted by 1975yellowC3
Thanks guys.
Good move on checking grounds - especially if you are indeed talkking about a C3. As you probably already know, they seem to frequently have ground problems.
If you are not already aware, corvetteforum.com has a C3 section.
Terry
sjkonyndyk 01-09-2011 06:45 PM
Sand the metal bare at the ground, and if you are still questioning it use a pare of jumper cables from the negative battery one to the block or intake and one to the metal section of body.
1975yellowC3 01-10-2011 06:16 PM
Thanks for the all the help everybody. Haven't had a chance to do anything this evening, but I am definitely going to try the jumper cable trick.
It is really weird to me that if I went out to the garage right now, it would crank just fine. After running for a minute or so, it will not turn it over again. It is running extremely rich right now. Think there is any chance that it is hydraulically locking? I can't be a heat soak problem, because the motor isn't even remotely warm when this happens. :confused:
timothale 01-10-2011 06:28 PM
cyl wash ?
I've heard guys say that overly rich will wash down the Cylinder walls. leaving no oil coating, making more cylinder wall-piston ring friction, I don't know if that is true. In the old days a few guys used other GM starters on their SBC, think big olds, not sure.
1975yellowC3 01-11-2011 07:29 PM
Thanks for the all the help guys. I think I found my problem. I took the battery up to Napa and it tested bad. As usual, I overlooked the obvious problem! :spank:
