High-torque starter recommendations.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2003, 09:08 PM
79454's Avatar
Cool High-torque starter recommendations..
I've determined that I need a High-torque, gear reduction mini starter for my rebuilt 454. I would like to get one that is rated for a minimum of 11:1(to play it safe..think i'm at about 10:1)....does anyone have any particluar brands/models etc.. that they recommend, or any that are recommended to stay away from? Thanks
-Paul
Old 10-17-2003, 05:31 AM
dollybud's Avatar
Talking
Check out Summit, they have Powermaster X5 ($200.00) that's good to 18.1 or Powermaster Master/Torque up to 12.1($150.00). CSI makes real quality starters but are a bit pricey.
Tom
Old 10-17-2003, 07:59 AM
Wrencher's Avatar
Paul, not to change your mind or anything, but, 10-1 isn't too much for a properly operating reg. starter. Temp or timing, connections and/ or faulty starter?
Old 10-17-2003, 08:18 AM
Chevymetal's Avatar
High Octane
Paul,
High torque starters are always nice to have, but certainly in your case (10:1) not necessary. They help if you have a tight fit with your headers and most any high torque mini starter are rated to turn over an 18:1 cr engine (of course on a gas engine you won't have that).
I have a power master that has never let me down.
James
Old 10-17-2003, 09:13 AM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Paul.
Check out Ebay. There mini starters are about 50-80 bucks less depending on the brand you choose. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 10-17-2003, 09:49 AM
79454's Avatar
Thanks for the info...I'm still going to check out the timing, try retarding it a bit and see if that helps. Everything else has proven to be fine..battery, starter, connections...SO, I guess the timing is pretty much all it could be..
Just thought I would get some info on these starters too, for if I go to one.. Thanks guys
-Paul
Old 10-17-2003, 12:12 PM
Im running a CSI on both of my camaros and love them.
Old 10-17-2003, 02:50 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Hemmie is right on, I got a GM Performance mini for $78.00 NIB off eBay.
If you'd rather trouble shoot your starter, you might consider overheating...get a shield for it.
-Larry
Old 10-17-2003, 03:05 PM
New Member
I've had good luck with the cvr starter from jegs or summit. Only $150. and it's been in the car a few years with no complaints.
Old 10-25-2003, 04:24 PM
79454's Avatar
Retarding the timing a bit did the trick, fires right up with no problem now; without a high-torque. Thanks guys!
Old 10-25-2003, 08:28 PM
minesblown's Avatar
you can save about 20 lbs with the one they sell here www.dragraceparts.com
