High torque starter woes - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2008, 03:46 PM
dawg's Avatar
NAVY VETERAN
I have a high torque starter (proform) on my 406 (staggered bolt pattern)
starter bolts loosen up after awhile and of course the nasty grinding noise.
Ive locktited the bolts but still they came loose.
anyone know where i can get a set of starter bolts with lock wire holes in them?
Old 09-03-2008, 04:49 PM
Drill the heads for the tie wire in a drill press or mill.
I had issues on my dragster till I went with a good bolt (ARP) I think the cheaper bolts were streching in the thread area and comming loose.
Old 09-03-2008, 05:34 PM
T-bucket23's Avatar
Wiki Edits: 26
Stage 8 sells locking starter bolts. What color locktite did you use. The blue should hold them.
Chet
Old 09-03-2008, 05:48 PM
dawg's Avatar
NAVY VETERAN
I used blue
I cant use the stage8 bolts because there isnt anything to lock them against.
bolt heads are on a flat section of the starter block.
Old 09-03-2008, 07:27 PM
MrB MrB is offline
I'm putting together a 406 SBC right now and picked up a mini-starter at a swap meet. Brand new, but had no bolts. The standard SBC bolts won't work on the starter I have as the shank is too small & rattles around in there. I don't know the brand (maybe a Pro-Form?), but I suspect that you may have the same issue? I haven't been able to find bolts, yet, so IF I can't, I intend to drill out the holes in the starter and insert\weld steel tubes in each to make them fit snug.
Only as a last resort, tho. I prefer to get larger shank bolts...
Check your bolts to see if they fit snug in the holes.
Old 09-06-2008, 04:13 PM
dawg's Avatar
NAVY VETERAN
Ok I found the problem!
damn starter block is cracked 1/2 way through on outside edge of the mount bolt.
block was cast aluminum and just bought another mini starter with a billet starter block.
Ill just have to heliarc the old one for repair and use that as a backup.
Old 09-07-2008, 10:50 AM
dawg's Avatar
NAVY VETERAN
ill take a few pics soon.
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Starter woes Again dollybud Electrical 11 09-01-2004 04:16 PM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 08:04 AM
Starter Solution dollybud Electrical 0 09-30-2003 06:42 AM
