high volume fuel pump? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2008, 07:55 PM
runn141's Avatar
will a 110 gph high volume fuel pump with 6psi max be too much and flood the carb. this is what im experiencing, has anyone else?
Old 09-06-2008, 08:06 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
6 psi is not excessive in a carb'd application. The 110 gph is the volume of gas it can deliver but at a low pressure. If you are having flooding problems it is most likely due to the needle & seat not closing the fuel supply off completely or the float(s) are set too high causing the same condition.
Old 09-07-2008, 05:13 PM
techinspector1's Avatar
Wiki Edits: 326
I don't understand why you guys want to run the fuel pressure right up at the ragged edge. Any comtemporary 4-bbl will run great at 5 psi, as long as you run fuel lines large enough to cover volume.
Old 09-07-2008, 08:45 PM
runn141's Avatar
i dont want too, my carb will run on another car with a stock 6psi oem pump. but will flood with a high volume 110 gph pump at 6psi.
Old 09-08-2008, 10:17 PM
Wiki Edits: 326
6 psi is 6 psi, no matter if the pump flows 1,000 gallons per hour. I'm thinkin' you didn't have a valid fuel pressure gauge on either car and are guessing. If the carb will run ok on the other car, then the other car has less fuel pressure at the carb inlet than your car does. Plain and simple.
Old 09-09-2008, 11:43 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
There you go using common sense again, I would have thought you would have learned about that by now...
Old 09-10-2008, 03:17 AM
runn141's Avatar
update:
i have to change the piston rings now because there is not enough compression to start the motor. the gas has damaged the back 4 cylinders. and i did have valid fuel pressure gauge and was not guessing.
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
High Volume Oil Pump Question Mustangsaly Engine 4 06-11-2005 08:05 PM
high pressure fuel pump? Siggy_Freud Engine 5 02-16-2004 05:39 PM
93 dodge shadow fuel pump repair junkie Electrical 2 10-02-2003 08:05 AM
