High volume oil pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2011, 11:26 AM
what's your guys opinions on high volume oil pumps? i've got a guy tryin to tell me they rob up to 30 hp and i should switch back to a regular oil pump. its in a small block chevy.
Old 06-29-2011, 11:38 AM
malc's Avatar
Born To Be Mild
I had one for awhile, no problems whatsoever.
Old 06-29-2011, 11:46 AM
327NUT's Avatar
I think the general consensus's is...for a street driven car the stock or Melling M-55 will provide ample oil pressure. I think 30 hp is waaay too much but it does take some extra hp to spin it. Some other things to consider, do a search here for more info reg. high pressure/ high volume pumps.
Old 06-29-2011, 12:57 PM
At 9000 RPM; like the water pump and the pump driven fan, the power extraction is geometrically variable by RPM. That is it goes up in exponents. At low RPMs hardly anything, by 6000 its getting up into the range of a couple, three horsepower, above 6 it goes crazy really fast.
That said there's different reasons for using a high output pump. If bearing clearances are exceptionally wide, if the engine is going to be used at high loading but low RPMs are situations where more than OEM oiling is warranted. The back side of this is oil control, if you're going to put more in the result is more windage. All this oil flying about the crankcase probably improves flat tappet life but it's difficult for the rings to keep out of the combustion chambers. This leads to the need for better control using strippers to catch the oil slung off the crank and direct it to the pan instead of allowing the crank windage to cause it to deflect up the right bank and into the cylinder bores. It's also a good idea to add a windage tray, but use one with a lot of vents facing into the direction of crank rotation to catch the fly-off and direct it into the pan. If this is a competition engine you also need added pan capacity simply to reduce the frequency a given thimble of oil gets cycled, a little rest allows time for entrained crankcase vapor to escape the oil. There is also a need for dams and doors that keep the oil around the pick up, this is a big issue with hammer head pans as these have plenty of space for oil to go where the pick up isn't.
Bogie
Do I have a high volume or high pressure oil pump ? y2k600f4 Engine 6 12-16-2008 07:12 PM
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 07:48 PM
High volume oil pump????? fireforsin Engine 10 10-26-2004 08:56 AM
high volume or high pressure pump? bullheimer Engine 3 05-09-2004 05:19 PM
SBC High Volume Oil Pump 360Camaro Engine 4 08-18-2003 11:43 PM
