High Volume Oil Pump Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2005, 05:50 PM
Mustangsaly's Avatar
in the HP And ET guestimation thread, it was said that a high volume oil pump was robbing about half a dozen horse,
i thought That a high volume oil pump was good ?
i'm gona build a strong street 350 sbc what oil pump should i use ?
Mustangsaly
Old 06-11-2005, 06:30 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
use a stock pump, upgrade the sping if you like unless you're running a motor that sees a long period of high RPM stretches. High volume pumps move more fluid, and we're talking about a mechanical device here. The more fluid you move, the more power it takes. Some say up to 10-12 horse. I tend to believe its probably more like 5-8.
Furthermore, you can suck your oil pan dry (so they say, I've never seen it happen) with a HVHP oil pump.
Chevy motors have great oiling from the factory, unless you're running nextel cup, use a stock unit.
K
Old 06-11-2005, 07:32 PM
Thanks, makes sence
Mustangsaly
Old 06-11-2005, 07:55 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
What killer said is right on the money.
The purpose of a high volume pump is to compensate for the increased bearing clearances in hi HP/ hi RPM engines. Most of the GM factory hi HP engines, if I remember correctly, use a std. volume/ hi pressure pump.
As far as sucking the pan dry, it can get close with a stk. oil pan on a hi RPM engine. Go with increased pressure, not volume unless absolutely necessary.
Old 06-11-2005, 08:05 PM
strikingthematch's Avatar
Pure American Muscle
Last journal entry: Still Going
If your going to use a pump just get a new melling M55 pump. It is a slightly upgraded version of the old chevy stock pump. Cheap and effective the way to go...M55
Chris
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 01:51 PM
High Volume Oil Pump 1948Butch Engine 8 02-10-2005 01:25 AM
Oil Preshure ve3ham Engine 9 10-28-2004 02:36 PM
question on cam & oil pump install chev 350 solowookie Engine 16 04-03-2002 04:25 PM
