High Volume/Pressure Oil Pump Question... - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2007, 07:02 PM
Last journal entry: Rear End Disassembly
Hi I have a 340 chrysler motor with low oil pressure and ticking lifters. at idle im seeing around 7psi when hot. i would like to add a new oil pump to temporarily solve this problem while i slowly build another motor. i read some posts stating that a high volume melling pump with hardened shaft will be good for low and high rpms.
What I am confused about is will I need a deeper pan and more oil with a high volume pump? Or can I just bolt on a high volume pump with a hardened shaft?
Also, would get rid of noisy lifters?
Old 05-14-2007, 07:18 PM
Jmark's Avatar
My experience with the high volumn/high pressure pumps with a stock pan is fine. If you were spinning obsenely high rpms for long periods of time, you might benefit from a bigger pan.
On the lifters, since the 340 has rail mounted rockers, adjustment is not an option, atleast as far as I know. Maybe it's just worn out? Or maybe the extra pressure will help some.
Mark
Valce cover Oil leak problem / PCV system question hotrodf1 Engine 7 05-01-2007 02:44 PM
Oil Preshure ve3ham Engine 9 10-28-2004 02:36 PM
correct oil pump Blob Engine 1 12-18-2003 06:58 PM
SBC High Volume Oil Pump 360Camaro Engine 4 08-18-2003 11:43 PM
question on cam & oil pump install chev 350 solowookie Engine 16 04-03-2002 04:25 PM
