High Volume or Standard Oil Pump?? SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2007, 04:41 PM
89SDime's Avatar
I know this has been asked 100 times but from what ive read and what my engine builder says are differnet.
I have read numerious times that a high volume will suck ur pan dry.
The guy building my engine is telling me a standard pump will probaly not be enough and i should switch to high volume or atleast a high pressure.
Engine: 383 Chevy 9.5 CR never see over 6500rpm street motor
8 quart mororso pan
help??
Old 07-09-2007, 04:49 PM
That would be with a stock pan you should be ok with the 8qt pan w/ high volume imho.
Old 07-09-2007, 05:00 PM
A hocus pokus pump is not useful on a street driven car and probably only marginally helpful on an all out drag car. Much more helpful are wide open drains from the heads and a good windage setup.
Old 07-09-2007, 05:29 PM
Mustangsaly's Avatar
what is best for a weekend street / strip SBC with say a 7qt moroso pan and a stock oil pump or a high volume or a high pressure pump ?
what is best for a weekend street / strip SBC with say a stock pan and a stock oil pump or a high volume or a high pressure pump ?
Old 07-09-2007, 05:38 PM
What was the reason your builder thought a stock pump would not be enough?
What is best...whatever gives you the target pressures you are looking for. It's that simple. We like to setup the pumps to give 65 or so PSI under full throttle conditions, although 55 does not bother us. If the volume of a stock pump is not adequate then a HV pump is needed. On a stock 350 or 400 small block with a flat tappet hyd or solid cam and .002 or so on the rods and .025 or so on the mains a standard pump is all you will ever need. On a Dart block wtih priority main oiling, solid roller without restrictors and spring oiliers a high volume will be needed.
Old 07-09-2007, 05:48 PM
DoubleVision's Avatar
I`ve ran high volume pumps on stock systems and never had one "suck the pan dry" That`s a myth. When I learned I didn`t need high volume pumps I stopped using them. A small block chevy from the factory has a excellant oiling system, and if the clearences are on spec it`ll have outstanding oil pressure. My 4.3 V6 has a stock pump, it never goes below 30 psi, and anything past 2300 RPM it`s on 60 psi. On a small block chevy you can deburr the rear drain back holes, these holes always have casting flash on them and really slow down the oil rate back to the pan, I always take my carbide cutter and die grinder and smooth the flash away and widen the holes, this greatly improves oil drainback and cuts oil falling directly on the crank in the lifter valley. I do this before the block goes to the machine shop to be assured all the debris are cleaned. I also never trust the plastic collar to lock the drive rod, I always use the melling hardened rod. I would only use a high volume pump if I were revving it over 6500 on a steady basis, also have to remember, a higher volume pump takes more power to drive. There are several mods you can do to the stock pump as well. Like opening it up, mark the gears, then remove them, the use the carbide cutter to deburr the opening and slightly widen it. you can do the same on the rear main cap where the pump sits, deburr and smooth the entry point of casting flash.
Old 07-09-2007, 08:58 PM
Another drainback mod is to drill a 1/2" hole in the webbing near the rear main cap, this provides an easy route for oil to get to the pan in the back of the block -otherwise it is always fighting the crankshaft rear counterweight.
BBC oil pump question JamesRS Engine 11 07-13-2012 01:14 PM
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 05:03 AM
How beneficial is a hi volume oil pump with stock clearances? surfshark Engine 6 10-01-2006 01:11 PM
High Volume Oil Pump 1948Butch Engine 8 02-10-2005 01:25 AM
High Volume Oil Pump (Good or Bad) ? white66coupe Engine 5 11-05-2002 03:27 PM
