high zinc content oils - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2008, 01:00 PM
I was doing some research here at work and found some numbers for zinc content in oil zinc/phosphorous
Quaker state Q racing:200/180
pennzoil racing 20w50:196/180
Carquest 15w40 :160/150
Shell Rottella 15w40 :140/130
VR1 20w50 :130/120
Cosworth Racing :125/115
Carquest 10w30 :110/100
Old 04-14-2008, 01:15 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Is quaker state Q a synthetic?
Old 04-14-2008, 01:34 PM
yes it is It usually has to be ordered through any parts
store
Old 04-14-2008, 01:41 PM
If you're basing your research on the material data sheets provided by the oil manufacturer's your findings are mostelikely wrong. They do not update the information often enough and many have found through oil analysis that the zinc content is most times lower than advertised. Check out the chevelletech performance forum for a lot of good info on the subject. We may all need to run race oils soon.
Old 04-14-2008, 05:54 PM
Wiki Edits: 31
Carquest is just Valvoline, nothing special
Old 04-16-2008, 01:17 PM
Saw a message thread, somewhere, where Blackstone? labs was taken to task for incorrect analysis on Valvoline oil for ZDDP. They finally admitted that their equipment was improperly calibrated when the tests were done. The questioning person sent a split sample of VR1 to two different labs in Houston who both reported ZDDP levels slightly higher than the oil company's spec sheet.
I believe this thread was on one of the Chevy /GM forums.
Old 04-16-2008, 04:07 PM
thats true carquest is bottled by the same company as valvoline,but then what oils should we use for break in?and non break in for flat tappet?
Old 04-16-2008, 06:51 PM
I thought vr was good break in oil?
Old 04-17-2008, 06:11 AM
I asume you mean for normal use in the 'non break-in' part. Brad Penn has a break in oil designed for flat tappets, also Cen-Pe-Co and many other 'racing' oils. The idea that once the cam/lifter interface is wear mated you no longer need the additives will lead you to troubles down the road, sooner, or later. If you check the CompCams site their 'flat tappet cam tech bulletin' was revised 3/11/08. This should be common knowledge by now. JMO
I am not a paid advertiser or endorser of any known product or service of this earth or its solar system.
Old 04-17-2008, 11:07 AM
where do they sell brad penn?
Old 04-17-2008, 06:51 PM
L.e.c.
I'm using MotorHead Classic Motor Oil (motorheadoil.com) and it typically has over 1500 ppm zinc (and yes, I've had it lab-tested). It isn't synthetic though..but if you like the synthetics (I don't) they sell their zddp additive separately, and you can use THAT with any oil...it boost a 5 quart oil-change by 700 ppm.
Old 04-17-2008, 07:55 PM
Is this really good oil?
Last edited by rreruption; 04-17-2008 at 08:05 PM. Reason: forgot to write something
Old 04-18-2008, 12:24 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
bonzipenguins,
Below is the information you asked for.
Rich
http://www.bradpennracing.com/
PPC Lubricants
Bill Kipphorn Distributor 800 772 5823
Old 04-18-2008, 02:16 PM
Last wiki edit: Quadrajet
Wiki Edits: 7
An interesting note on the revised comp cam bulletin linked to in Stroke's post. It appears that the change has been to remove any reference to the Shell Rotella T diesel oil. This was expected as new diesels are required to run cat converters and therefore the new oil must have its ZDDP reduced.
I'm not really looking forward to special ordering my oil for $5 or more per quart...
Old 04-18-2008, 02:58 PM
Hi,
I like you don't like the price,
but at least the money goes to
a US company for Pure Pennsylvania crude,
instead of some Saudi (or whatever you call them)
getting the money, & using it to try & kill us.
Rich
high volume and high pressure oil pumps can destroy cam and distributor gears! Knobie Engine 75 02-13-2011 02:22 PM
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 07:48 PM
283 vacuum advance nickeldimerods Engine 3 01-14-2006 05:13 PM
High Volume Oil Pump (Good or Bad) ? white66coupe Engine 5 11-05-2002 03:27 PM
S/B chevy nickel content?? 78 monte Engine 2 08-28-2002 03:00 PM
