Higher compression for my 70 Chevy c10 307 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2012, 11:36 PM
I have a 70 c10 307 chevy that has used propane since 1988. Propane has 108 octane, thus the 307 low compression ratio is not optimizing mpg. I purchased the truck 4 months ago, have a 4:10 ? gear ratio at present and no overdrive. I am presently achieving around 15 mpg combined village and hiway driving. I plan to change the rear end ratio to 3:08 and will probable be getting around 16-17 mpg on the same roads. 15" wheels, stock tire size.
It needs a valve job at 140,000 miles I am aware of the need for hardened valves for the propane combustion. I am interested in the options that I can build into this engine to increase the comp ratio. I am aware of a threshold where the propane fuel will auto ignite due to high compression. What is that point and what is practical as I consider all that can optimize the propane fuel.
I am paying $2.25 per gallon at present. That calcs my actual cost per mile in the 28-30 mpg range. I am hesitant to discuss this as big brother will certainly tax the hell out of propane if it becomes more popular.
tjjack10
Northern California
Old 05-29-2012, 02:05 AM
JeffB's Avatar
Heads from a Chevy 305 with the 416 castings should do the trick and they are wallet friendly.
Old 05-29-2012, 12:21 PM
propane
If I remember correctly you don,t really want to exceed 11:1 on propane. It responds well to a turbo though, along with a little water /ethanol or methanol injection.
Old 05-30-2012, 12:43 AM
c10 307 propane
Can I bore it to a 327 ? If so which heads and how would this affect compression?
Old 05-30-2012, 02:24 PM
JeffB's Avatar
NO,But you can end up with a 327 by using a 350 block your 307 crank and 327 pistons.
Old 05-30-2012, 04:05 PM
So I would not be gaining much , I think your suggestion of different heads is the most practical. I am 55, occasionally get it on, but don't need to impress anyone. Not to say I won't develop that need in time.
I'm an inactive contractor, due to the meltdown. Money isn't as easy as it was pre 07.
Olds 307 compression? finsman Engine 14 10-30-2010 10:30 AM
Chevy 307 - POB 307? El C Engine 13 10-15-2009 05:05 AM
307 sbc compression ratio's? C.W Engine 6 06-16-2007 05:37 AM
72 C10 - 307 vs 283 - Need Torque icegnome Engine 5 12-03-2002 10:43 AM
