which is the highest coil spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2005, 09:51 PM
New Member
hey my names is carl am trying to put the highest coilover spring there is on a 81 bonneville.which is the one i can put on there 7",8",9",10",12",14". Can some one tell me????
Old 05-25-2005, 01:54 PM
willys36@aol.com's Avatar
Wiki Edits: 21
I think you are not getting any responses since no one really can understand your question. Try to rephrase it by assuming the reader does not have the insight you do, in fact that he has no clue what you know. Questions like this really benefit from a picture or two also.
Coil Spring Spacer Bill Ford Suspension - Brakes - Steering 4 06-06-2004 09:24 PM
If I cut a coil spring Bluepen Suspension - Brakes - Steering 2 06-01-2004 06:06 AM
HELP….HELP info on Moog coil spring, Im running iut of time 406chevelle Suspension - Brakes - Steering 7 04-25-2004 09:39 AM
info on Moog coil spring 406chevelle Suspension - Brakes - Steering 0 04-22-2004 09:26 AM
Coil Spring Movement Dave E Shank Suspension - Brakes - Steering 9 03-26-2004 07:36 AM
