Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - highest compression on premium
Old 04-01-2003, 09:45 PM
nickel333 nickel333 is offline
Bullheimer no theyre not, you dont have a fricken clue what your talking about, shut up. Theyre using carborators and an aftermarket ignition system {mallary, MSD etc}, a good cooling system {aluminum radiator, heads, intake, and water pump} and aparently more resources than the typical hot rod subscription. And the key to it all for the last damn time is.....TADAA.. A cam with a longer duration. If you want to argue about this any more then we can start an arguement thread on this topic. If not then do some research on Dynamic compression and cranking PSI and learn a little
