Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Highest Compression For The Street
Old 05-25-2005, 08:26 PM
Rick WI Rick WI is offline
Originally Posted by Rhansen
Assuming the timing is not excessively retarded that pretty much blows that theory.
Build your next motor with a ton of compression and pump gas and maybe you'll be the 2nd in a million to get away with it. Not doubting lluciano77 but we see detonation on iron headed motors at 10:1 a lot, and that is with 93. 11:1 with aluminum heads such as AFR 195's is not easy either with pump 93. Boarderline on the edge.
