Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - highway gear too tall?
Old 01-22-2010, 05:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Hwyhogg
Thanks. BTW,it has about 236/230 at .500, 9.5 compression, 28" tires,and about 2000 converter.
Just do the things that you know will help torque at the bottom like dual plane intake, good ignition w/a good advance curve, keep the header diameter moderate relative to the engine size, use a connector between the exhaust after the collector but before the muffs, keep the exhaust diameter =/< 2.5", size the carb correctly and in your case, I'd even suggest one of the annular booster-type carbs like the Truck Avenger.
Good luck.
