highway gear too tall?
Got a 56 panel truck that weighs about 3900 lbs w/driver. It will have a460 with about 500+ lbs torque. Will that torque make a 2.75 gear liveable or will it feel like a dog? It has a C6. I got the tall gear as a substitute for a costly overdrive...
Many years ago I had a '67 Pontiac Catalina with a High Cpmpression 400 2 Bbl., TH400 and 2.29 gears. It weighed right about 4,200 Lbs. dripping wet w/o driver. It would lay down a black stripe for 2 blocks, bury the speedometer in a little over a half mile and got an homest 20 MPG. Now time may have "fuzzied" the details a bit
but if it has they aren't far from reality. You'll be fine.
Thanks. BTW,it has about 236/230 at .500, 9.5 compression, 28" tires,and about 2000 converter.
Good luck. |
I did a 454 with a TH400 (similar ratios to the C6) with large (255/70-15) tires and it was pretty well matched. The cam was 218/224 with a stock stall in a 73 Impala S/W with 2.73 gears. It wouldn't roast tires, but there was plenty of torque to get you moving quickly and enough "leg" to make highway cruising nice and easy. Perfectly matched? No. 3.08 or 3.42 would have been perfect for that cam and tires, but it wasn't enough of an inconvenience for me to shell out the money for a new gearset for an obsolete axle that was only used for three years.
A 28" tire has an actual loaded effective diameter of about 26.3" so you'd be turning a hair over 1900 assuming no converter slippage and there would be some. After reading your cam specs you may want to consider a little lower gear like a 3.08 or 3.23. Even in a 460 that might be a little "iffy" with 2.75's, not saying it wouldn't work but it does change the equation a bit.
I'm using the edlebrock rpm performer intake with a 770 street avenger. I double-checked the cam specs at .050; 224 int/234 exh. The lift is .544int and .569 exh. It has the older style CJ aluminum heads from Motorsports, valves 2.19 int/1.71 exh.. Maybe after truck is up and running, I'll look into a lower gear, (3.00 or 3.25). I understand I need to keep the cruising rpm above the stall speed for less slippage, is that correct? I'd like to take road trips and be able to cruise at 65-70 mph. If I win the lotto, I'd go gear vendors overdrive and maybe a 3.55 or steeper for stop light fun
.....Thanks to all,James |
| How do I remove the timing chain on a 350? | piniongear | Engine | 9 | 09-20-2010 09:39 PM |
| Crankshaft Timing Gear Installation? | starnest | Engine | 12 | 03-03-2008 11:56 AM |
| GEar DRIVE QUESTION! Werird Noise! | boneyard Buick | Engine | 7 | 02-14-2008 04:45 PM |
| Need Help with 700r4 No 4th Gear | Jackson63 | Transmission - Rearend | 6 | 10-09-2006 09:35 PM |
| Roller cam/distributor gear information | Jmark | Engine | 0 | 12-29-2003 03:56 PM |
