hilborn mechanical fuel injection - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2009, 11:54 AM
is it possible to use Hilborn mechanical fuel injection on the street..running 327ci in my 33 chevy 5 window coupe.only wanted to use because it looks awesome.
Old 03-21-2009, 01:10 PM
BOBCRMAN@aol.com's Avatar
It is possible, but not something to do unless you like to constantly work on the engine.
They have to be set up in a rich condition for any kind of mid-range drivability (no acc pumps). And just about flooded (manually, with a squeeze bottle) with fuel to start in the cooler mornings (no choke action).
A couple of locals have had early setups converted to electronic systems. The old look with modern drivability.
Old 03-21-2009, 01:55 PM
techinspector1's Avatar
Wiki Edits: 326
Blower Drive Service builds the EFI units that Bob mentioned...
http://www.blowerdriveservice.com/efigallery.php
There may be other sources as well.
Old 03-21-2009, 02:23 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You can also go with a Megasquirt system if you are up to building your own circuit boards..works just fine..I have thought about that for a 302 Ford and I did find the Hilborn plate and tubes at a swap meet but the guy wanted waaay more than I wanted to spend that day..
Sam
Old 03-22-2009, 09:13 AM
bentwings's Avatar
bentwings
When converted to EFI they work nice otherwise leave them to the race cars. They are difficult to get to run so you could sit in traffic.
Old 03-22-2009, 03:43 PM
you could always go with webber carbs they look pretty decent. or one of those Don Garlet fake carb covers
Old 03-22-2009, 04:31 PM
FEDDO's Avatar
I run one on a fed, and i use a small elect pump to prime it and get it running. keeps someone from having to keep priming it. I have good throttle response from idle to wot.
Old 03-24-2009, 11:44 AM
mech fuel injection
thanks fedo
I was thinking their was a way to prime.
wondering is it possible to use a electric fuel pump.
thanks from Ivan
Old 03-24-2009, 11:51 AM
bentwings's Avatar
bentwings
These use a positive displacement fuel pump. They depend on the varible pressure and flow. They use various bypasses and jets called 'pills'. Very simply, they idle and run full throttle by design. The sprint car guys make some changes to allow part throttle but it is still not a very streetable system.
EFI is the way to go if you really want one of these.
Old 03-24-2009, 12:10 PM
not to hyjack you thread but could someone please point me in the direction of refurbishing one of these hilborns. my dad has one hes had for many years and eventually he wants to use it, but I dont know where to even start with with it. Ineed the whole setup what pumps to use how to set up the linkage ect. thanks in advance
Old 03-24-2009, 12:40 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Straight to Hillborn, where else?
http://www.hilborninjection.com/
Blower with fuel injection...........?? poncho62 Engine 61 10-12-2015 04:04 PM
mechanical fuel injection bondsman Engine 7 04-15-2010 11:24 PM
Octane Booster Info SLR_65 Engine 46 09-30-2007 09:01 AM
Help with my Fuel Injection Magikal Engine 2 04-28-2007 09:31 AM
Mechanical fuel injection?? colaus Engine 8 10-30-2002 12:25 AM
