On most hinge styles I usually use an airchisel with a straight punch bit to jar the pins loose, then grab the pin with medium sized vise grips and tap the visegrips pulling the pin out. A long punch and hammer will also work instead of the airchisel. It's been years since I've done a second generation Nova but I don't recall any real challenges. You usually need to pry out the hinge spring before popping the pins. Tape up your door and fender edges to avoid chipping any paint, cardboard taped in between the panels will also protect the edges. Get both pins popped loose then pull the top then the bottom and remove the door. Make sure your new pins and bushings have a good tight fit or they won't last long. Use some moly grease when assembling.
I feel your pain. I had to take the doors off an older cavalier to do some work on them and they are the same way. Welded on hinges, so you have to pull the pins to remove the doors. Stupid idea, probably cheaper and easier to manufacture. I finally got the pins out by spraying penetrating oil on them, using a punch to start them out, and then using a long needle nose vice grip just under the head of the pin and hammering out. Not a whole lot of room to work and swing a hammer though. Needless to say I put new pins and bushings in when I put the doors back on.
Guys thanks for all the tips, i appreciate it. It turns out my trouble was due to me being a complete dumb@ss. I was sitting in the car while trying to pop the pin putting more pressure on the pin lol i knelt besides the car and it moved with the first tap lol im an idiot what can i say thanks anyways guys
Always remember...The only dumb question is the one thats never asked. Glad you got it figured out!
| Best ways to straighten a twisted repro door? | Ripped | Body - Exterior | 13 | 07-04-2005 07:29 AM |
| body parts fitting | anyoldchevy | Body - Exterior | 10 | 02-20-2005 09:20 AM |
| Door Alignment | Ron M | Body - Exterior | 2 | 08-21-2004 01:43 AM |
| Removing fenders? | Jag Daddy | Body - Exterior | 3 | 11-26-2003 04:42 AM |
| body panel alignment | gmonkey | Body - Exterior | 5 | 09-01-2003 06:50 PM |
