hip precautions and roll cage - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2012, 01:37 PM
471A
My 29 street-strip A sedan is a joy to drag race, running high 10s. My continued enjoyment is, however, now questionable, due to a mismatch between the design of my NHRA rollcage and the hip precautions which I now must follow due to total joint replacement of my left hip. Simply put, a person with a replaced hip must avoid postures in which the knee is raised higher than the hip. Phrased in terms of angles, one must keep lower than 90 degrees the angle between the knee and an imaginary vertical line drawn from head to toe in a standing position. In my A, I must bend my knee to almost 135 degrees just to slide into the driver's seat and, when seated, my knees are both higher than my hip, at about 120 degrees. My physical therapist suggested that, for starters, I move the seat back 6-10 inches so that my legs could then be less than the 90 degree limit. That might be possible by modifying the driver's side roll cage to accommodate a recessed "funny car" style cage surrounding the driver, allowing the seat to then be back into into the now- recessed space. This does not, however, answer how one gets into that recessed seat without running afoul of the 90 degree limit.
I would be pleased to hear from any with suggestions, especially any who have had to address hip precaution issues in configuring their own car's interior.
Old 02-26-2012, 08:09 PM
454 Rattler's Avatar
NEVER SATISFIED !!
Does NHRA still allow "swing-out" side bars on the cage ? Would that help ?
454 RATTLER
Old 02-26-2012, 09:03 PM
WDCreech's Avatar
Grumpy Old Goat Herder
471A, do you have enogh head room to raise the seat?
Old 02-26-2012, 10:09 PM
bentwings's Avatar
bentwings
Just off the top of my head....a swing out bar will help getting in/out I think. Consider a sliding seat with a low left side. Back into it, lift the feet and slide the seat back. In the race position you may be able to have a side support to compliment the seat.
BTW a custom aluminum seat is difficult to make and expensive. I just finished one for a Nostalgia Funnycar. Prefer not to make another one.
Old 02-27-2012, 07:13 PM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
I have had both total knee replacements and total left hip replacement.I am currently building a T-bucket with a 2" seat riser.so obviously my knees will be higher than my hips.I had my surgerys 3 years ago,my orthopaedic surgeon has always assured me that after the initial healing process that there is no reason that I can't do everything I used to do before the surgery.obviously I gave up riding motorcycles but thats just common sense.
Old 02-28-2012, 08:08 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I have some of the same issue in that I do not bend as well as I used to so getting in and out of a race cage can be a bit of a difficulty..I am working out the seating so when I am in I am in a comfortable position with my legs stretched out..Btw I am building my seats from steel as that is much easier than aluminum and the weight is not that much of a factor for me.. using a detachable steering wheel is a big help as well..
Sam
Ned roll bar,roll cage help in a g-body cutthroatkid Hotrodding Basics 1 12-20-2010 10:30 AM
s-10 roll cage carnahan General Rodding Tech 13 09-14-2010 07:09 AM
s10 roll cage awoodman General Rodding Tech 3 07-15-2010 03:27 AM
Roll cage?? GearHead69 Interior 32 11-23-2004 11:41 PM
ROLL Cage D M N Interior 11 08-26-2003 02:11 PM
