Hissing, Advance - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2002, 05:02 PM
66chevy2ss's Avatar
Post Hissing, Advance
Well, thanks to your guy'ses help, I got the Nova running.
I found TDC, put all the plugs back in (no easy task - - at least for me), and took the car for a spin. It was fast!
But it still idles bad, and now it makes a slight hissing sound.
Also, (this will probably qualify for the dumbest question of the year award) but when I'm doing initial timing I should be looking above the timing marker, which would mean I have to add 14 degrees to any number I get there. This is since the timing marker goes from 14 degrees to 0 degrees in the middle (and then to like 12 degrees ATDC at the bottom of the marker).
Old 08-18-2002, 05:47 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Talking
66, not sure about the timing degree thing, one area i know nothing about, but anyway, it sounds like you've left a vacuum port open on your carb or manifold. Make sure all your vac lines are where they should be. A hose off would cause rough idle and make the hissing noise you describe.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 08-18-2002, 05:52 PM
66chevy2ss's Avatar
Post
Thanks for the response.
I know that the vacuum advance line is hooked up (from the carb to the distributor - - I just installed it).
But what other vacuum ports/hoses are you speaking of?
Old 08-18-2002, 06:36 PM
MI2600's Avatar
Member# 3287
Post
Check the hose(s) that run off the vacuum port on the manifold behind the carb. Power brakes, a/c, and maybe other things run off this. Since it's close to the distributor, you may have bumped one.
Old 08-18-2002, 06:41 PM
MI2600's Avatar
Member# 3287
Post
I missed your actual question about timing. Without knowing more specifics of your engine, I would initially set the timing mark at about ten degrees, with the vacuum advance disconnected and the port plugged. You can work up from there if need be.
Old 08-18-2002, 07:23 PM
66chevy2ss's Avatar
Post
What I meant was that I should aiming the timing gun at the top of the marker, right?
When I turned the engine to TDC on #1, I lined up the "0" point on the marker with "TDC." Now this is right in the center of that marker, and it is difficult to see the harmonic balancer, and the corresponding numbers, behind it. But its easy enough to do when you're turning the engine really slowly. But when the engine is moving fast, its a different story.
So when I'm aiming the timing gun I have to look above the marker. The marker goes to 14 degrees BTDC.
I hope this made sense...
Old 08-18-2002, 09:28 PM
aka Duke of URL
Arrow
[quote]...it is difficult to see the harmonic balancer, and the corresponding numbers, behind it.<hr></blockquote>
Put a small dab of white paint on the marks (timing tab and damper) that you wish to set the timing at.
Old 08-19-2002, 08:24 AM
Cool
You need to invest in a book called (How to hot rod a small block chevy). Its a great book and will answer a lot of your questions.
[ August 19, 2002: Message edited by: hcheetwood ]</p>
Old 08-19-2002, 08:49 AM
66chevy2ss's Avatar
Post
Yeah, I got one of those books. Actually, two: 1 about modifying a small block, and the other about rebuilding it.
I guess when it comes to the simple stuff, though, like how to set the timing, I have to look to a different source.
The tips I get on this site are great, for example.
Old 08-19-2002, 03:25 PM
72 chevy's Avatar
Post
Ive been reading your posts 66, and thought i`d check in with ya. Hows it goin`?? Do you need more information about setting your base timing? It should be set at idle, with vacuum adv. disconnected.Your ignition will advance timing at higher RPM due to the mechanical advance, M12600 hit the nail on the head with his advice!!
[ August 19, 2002: Message edited by: 72 chevy ]</p>
Old 08-19-2002, 03:49 PM
66chevy2ss's Avatar
Post
Thanks for the reply. Its going o.k.
But I think the rough idle might be here to stay. The car does have a long duration cam in it. Everything seems to be configured for high rpm power: the cam, the short runner intake, 3.73 gears with the four speed manual.
So the question remains: how do I "initial time" something that won't make a smooth idle below 800-900 rpms?
Old 08-19-2002, 05:27 PM
Post
If all else fails you can take your distributor to a speed shop that has a distributor machine. Have them set up your distributor to match your engine and driving needs. when you get it back they will tell you where to set your base timing.
Old 08-19-2002, 05:33 PM
66chevy2ss's Avatar
Post
Its just the initial timing that I'm concerned about here. There's gotta' be an easier way.
Old 08-19-2002, 05:44 PM
aka Duke of URL
Arrow
The simplest way is with the use of a advance timing light. You would merely raise the rpm's to the point that all of the advance is (say 34 degrees @3000rpm's) and set the light at that amount. Rotate the distributor to where the mark(s) come to zero, and tighten her down.
You would want to make sure the advance curve (distributor) is correct for your engine and that would require a distributor machine or you can calibrate it on the car with a 360 degree timing tape or balancer and a good quality light and tachometer.
It might sound confusing but there are ways to time it correctly.
Old 08-19-2002, 06:09 PM
66chevy2ss's Avatar
Post
I don't think my timing light is like the one you speak of. For one thing, it doesn't have a "dial" on the front. Its of good quality, I think. I just bought it. To be honest, I don't know what an advance timing light does.
Is it possible to do with what I have?
