hissing noise from 7.3L turbo - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2006, 06:42 PM
53LEDSLED's Avatar
here to learn
Last journal entry: finishing up the skirts
it's a 99 F250, 7.3L (turbo) this only happened a couple of times but it bugs me. i hear a hissing noise only in the lower part of the RPM range, but not during idle and not after ~2200 RPM. im thinking it might be a leak from the turbo but to be honest, i haven't looked yet.
any clues?
Old 10-16-2006, 09:41 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
They were known to have little leaks where the intake tubing meets the sheet metal manifold on the passenger side... but that typically makes a hiss that gets louder and bigger the more pressure you make. Take the soft coupling off and inspect the intake manifold.
Its possible that the leak is only in your audible range at lower rpms. Maybe its still whistling past that point, but its so high pitched you can't hear it.
350 Turbo noise fredmanky Transmission - Rearend 0 05-02-2006 07:01 AM
Overefficient cooling system and popping noise. TVR383 Engine 8 11-09-2005 08:17 PM
pontiac 301 turbo gutted 87442lover Engine 10 04-30-2004 07:27 PM
Backpressure = Bad.... Right?? D M N Engine 20 01-02-2004 04:53 PM
valvetrain gurus: need help identifying mysterious valve noise blndweasel Engine 10 03-04-2003 07:59 PM
