hissing when braking - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2012, 09:35 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok first off anybody who knows me on here knows I usually ask a ton of questions about my projects bit this is about my dd.Its a 2 nd gen dodge ram with the 360 awhile back the hvac started acting funny replaced every vac line I could find still no fix,next found out my plenum is leaking so I orderd the parts to fix but I haven't yet&today I go to run some errands&when I push my brakes I hear a hissing like when the booster goes bad.Ive checked the booster&cylinder &there ok.Now Im wondering could my leaking plenum gasket be causing these problems?When I bought my mustang it did the same thing hissing when applying brakes but booster was ok...ended up being a rusted out reservoir.So input?Could it be the plenum?
Old 02-19-2012, 08:05 AM
T-bucket23's Avatar
Wiki Edits: 26
Bad booster
Chet
Old 02-19-2012, 08:57 AM
two cups of tea
Wiki Edits: 2
But Ive tested the booster&its holding vacuum.Ive turned it off&pumped brakes till hard held&started &it went slowly to ground&Ive started turned ofd&removed valve&heard the woosh.Like I said on my mustang it did the exact same thing&I replaced the booster&ot still did it ended up being a keak somewhere else that was causing the hiss@brakes&when I fixed that leak it fixed the hissing@brakes.Thats why Im wondering if its the plenum leak since it causes a vacuum leak in the crank case.
Old 02-19-2012, 07:55 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Just because it hold vacuum, does not mean it won't leak when the brakes are applies. Put shortly, there is a valve system on the booster that allows atmospheric pressure into the rear chamber when the brakes are applied. This is the ``boosting`` effect. There is a vacuum and an atmospheric valve, and if you hear hissing when applying brakes, this valve assembly is shot.
Old 02-19-2012, 08:05 PM
two cups of tea
Wiki Edits: 2
I got ya...not sure if this makes a difference or not but maybe my choice of words wasnt too good...its not reallyva hiss like a sucking or a leak more like when u push down on a kids bicycle air pump like shhw shhw sorry if thats a crappy explanation.
hissing noise after cranking timhollerbach96 Engine 7 02-27-2009 12:03 PM
hissing problem 18camaro Engine 3 03-06-2008 05:53 AM
Intermitent hissing sound dpjmw Engine 1 03-27-2005 10:37 PM
Hissing, Advance 66chevy2ss Engine 27 08-21-2002 08:50 AM
Hissing, Advance 66chevy2ss Engine 0 08-18-2002 05:03 PM
