Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hitting Hard When Shifting into Drive at Idle
Old 08-06-2009, 01:51 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
It will soften the blow but may not be enough. Why do you expect it to idle cold, without a choke, at the same idle speed as when it is warm?? It never will. Without a choke and fast idle cam on the carb, a hot rod engine will never idle without you "babysitting" the gas pedal. You are expecting too much.
