Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hitting Hard When Shifting into Drive at Idle
Old 09-06-2009, 06:14 PM
reflog's Avatar
reflog reflog is offline
I have the same problem on my 400. Is it possible that the low vacuum signal given by the bigger cam causes this problem. When I had the vacuum advance on the distributor disconnected the tranny shifted like a dream. Smooth into reverse and drive. As soon as I hooked up the vacuum advance to the distributor, it started to hit hard again. Is this possible??
Steve
