HK, or anybody!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2004, 04:29 PM
slider in wa's Avatar
Slider in Wa.
HK, or anybody!!
Looking for brand and number for sunrise orange paint. Can you help? Also do i have to use por 15 thinner to thin por 15 for spraying. Thanks a have a good day.
Slider in Wa.
Old 08-07-2004, 07:57 PM
BarryK's Avatar
Don't know the sunrise #!
Re the por 15 reducer, did not know they had one but DON"T
try anything else. This is a moisture cured product and urethane reducers have 500ppm of water for a good one, bad ones 8,000+
lacquer thinner can be as high as 15,000 ppm. Could cause major havoc!
barry
Old 08-08-2004, 02:20 PM
Slider in Wa.
Say Barry!
Glad i asked the question then!!! Yes they sell a thinner. Thank you for your input. I did not know about the moisture in thinners.
Have a fun day!
Slider
Old 08-08-2004, 02:29 PM
Wiki Edits: 49
Sprayed it on my frame last year. You absolutely need to use only their thinner if you want to spray POR 15. It's not just a simple paint and anything else will screw it up.
Centerline
