-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Hobbist & Rodder (http://www.hotrodders.com/forum/hobbist-rodder-215389.html)
will wrench 02-25-2012 03:15 PM
Hobbist & Rodder
Hello All,
New to HR and I need some information. I tired of using the junk air couplers from HF or any Milton, Amflo or cheap brands. Can anyone give me some air coupler manufacturers of a good High flow pnuematic quick coupler? I need one that will last and not leak.
Any Suggestions.?
michel 02-25-2012 04:45 PM
Originally Posted by will wrench
Hello All,
Any Suggestions.?
try hansen pneumatic ,it,s industrial.
Old Fool 02-25-2012 07:37 PM
If you mean the male coupling is breaking off,that is due to not having a whip hose on the tool. Never couple up solid and expect it to last.
S10xGN 02-26-2012 08:13 AM
I'd like to know too. I replaced all my couplers with Milton hi-flo's a few years back (don't remember the part number) and most of them leak enough when left coupled that I can no longer leave them coupled unless I'm using them. My compressor went from cycling every 20 or 30 minutes to once or twice a day. Besides that, they're much hard to assemble when pressured up.
Russ
tech69 02-27-2012 09:22 PM
i use milton t style couplers and never have problems. hf ones are garbage but not milton
1ownerT 02-28-2012 04:30 AM
http://www.legacymfg.com/Selection_G...lers_Plugs.pdf
http://www.zorotools.com/g/Color-Cod...Kits/00061028/
MARTINSR 02-28-2012 11:15 AM
It sounds like he is talking about them simply leaking, the HF couplers and fittings SUCK and WILL leak right out of the box. After just a little use they REALLY leak bad. Nope, only the best for me, my compressor isn't big enough to be wasting air thru leaking junk.
Old Fool 02-28-2012 11:37 AM
They have rubber seals in them, try lubing them once in a while with some silicone spray.
MARTINSR 02-28-2012 01:29 PM
I don't know about him but what I am referring to and I think this is part of what he is talking about are these nipples.
http://www.chemco.ca/Products/Air_To...ipples_007.jpg
Even with a quality coupler these parts from HF or the like are JUNK and leak from the get-go. As far as oiling them, not in my shop or anywhere that painting is being done.
Old Fool 02-29-2012 06:38 AM
I guess you never lube your air tools either?
Old Fool 02-29-2012 07:12 AM
Just reread this and noticed I said silicone, I meant to say non-silicone spray lube.
MARTINSR 02-29-2012 07:47 AM
Of course I lube my tools. This is no big deal here, there is no reason to lube a quality coupler, never did it in my life and have some that are decades old that don't leak. I have quality couplers and nipples. Tried the cheap ones, they were junk, went back to the quality ones.
Old Fool 02-29-2012 01:48 PM
Russ
Milton has repair kits for many of their couplers.
will wrench 03-22-2012 09:09 AM
Found the best air Coupler
2 Attachment(s)
I did some research and bought some couplers from Sherwin Williams Automotive they are Prevost Couplers. They have all the profile but what I was looking for was the High Flow style for the HVLP spray gun and the high demand air tool. These couplers work great and do not leak and this on pictured is the safety coupler, all you have to do is push the coupler once for disconnection. They are a composite but they are a robust heavy duty product and paid more for it but its worth it. I found out that Matco handles this product also. :)
66GMC 04-07-2012 08:55 AM
AirMax Industries (Canada)
Click on "Products"
