HobbyAir - Help my hood is blowing off! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2007, 05:23 PM
cab cab is offline
Hello All,
I painted for the first time this weekend and have learned a ton of things, but also encountered a few things I hadn;t planned on. As an example, I have a HobbyAir II setup wiht the Tyvek hood. It works well except the internal headband tends to pop off my head when the hood "inflates" (and when I move my head up and down - annoying when painting to say the least) - besides cranking the band down to 600psi on my head have any of you experienced this and have a solution?
Thanks,
Chris
Old 04-01-2007, 05:32 PM
Irelands child's Avatar
It needs to exhaust thru the bottom - are you "buttoning" it down too tight with your bunny suit collar?? I have had no problems with mine.
Dave
Irelands child
Old 04-02-2007, 06:27 AM
How about a chin strap ??
Old 04-02-2007, 09:06 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
turn down the pressure. it does not take much.
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
