HobbyAir Setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2006, 11:06 AM
cab cab is offline
HobbyAir Setup
Hello All,
I'm slowly acquiring tools prior to beginning paint and bodywork next year, and one of the items on my list is a fresh air supply setup (probably one of the HobbyAir units). My questions are:
1. Which mask style do you guys prefer - half mask, full face mask, or hood?
I'm actually leaning toward hood as I need full head coverage for ISO's anyway, but I'm concerned about visibility, bulk, etc.
2. I will be painting in my 2 car attached garaged (usual layers of plastic, box fans, A/C filters, no water heater in garage, etc.). How far away (which will determine the hose length) do these units actally need to be from the "booth" especaily as my booth is venting everything to the great outdoors where the fresh air unit will be!
Thanks,
Chris
Old 06-17-2006, 05:06 PM
Almost an old guy...
I have a hood and like it, no head sock to wear and I also have glasses and a full beard, both of which make anything else hard to use right. As long as your air unit is "upwind" of your booth exhaust you should be fine, just depends on which way the wind is blowing that day!
Lance
Old 06-20-2006, 09:05 PM
cab cab is offline
Thanks Lance. Any other opinions out there?
Chris
Old 06-20-2006, 09:54 PM
Id get a full mask over a half mask for painting.
ISO's still can get in your system throu your eyes.
As for the hood it depends. The 3M system hood is a joke or was at one point. When you turned your head the hood stayed put now blocking your view. It was a really PITA to use. But maybe the hobbyair unit is different.
Personally I dont see a problem with a full face mask...Eric
Old 06-21-2006, 02:38 PM
The hobbyair hood has a internal frame that that hood mounts to, it is an adjustable hat band rig like what is on a clear face shield you'd use for grinding. With that the hood moves with your head so you are always looking through the lens.
Lance
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Fast Xfi setup info ? x007 Engine 0 04-18-2006 12:58 PM
Need Advice: Which Brake Setup to Buy horvath Suspension - Brakes - Steering 5 08-27-2005 07:41 AM
Is my Torque Converter too big for my setup ?? 74NovaRat Engine 15 02-01-2005 08:23 AM
Setup Question (already running) Got Squeeze Engine 3 12-14-2002 10:53 PM
