HOK clearcoats - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2005, 11:38 AM
New Member
HOK clearcoats
I'm gonna be painting with House of Kolor paints. They list acrylic lacquer and urethane enamel clears. Which clearcoat should I use?
Old 08-22-2005, 11:48 AM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
I do not use HOK clears, however I have read allot of people love the UC-35... It seems to be the one of choice by those who use it.. It is also a high solids according to the tech sheets... http://www.hokpaint.com/man/UC-35-38.html
BK
Old 08-22-2005, 12:01 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Stay away from anything that's a Lacquer based product.
They cure by drying, and shrinking in the process.
This can go on for months. A urethane with hardener actually
cures by chemical reaction and is much more stable and durable.
Lacquer is yesterdays techology that most people don't use anymore.
It's not very durable.
Old 08-22-2005, 12:02 PM
New Member
BK
Yea it seems like that's the better choice. Especially since the tech sheet for the acrylics want 5 - 7 coats!
Old 08-22-2005, 12:21 PM
jcclark's Avatar
The Penny Pincher
To me 5 to 7 coats aren't enough for lacquer, for better painters
on this forum it may be but if you are going to rub it out ,
lacquer is very thin and it's so easy to sand thru.
It thins 100 to 200 percent so you're not putting on near
as much as you think. And you'll sand half of it off for buffing.
Old 08-22-2005, 02:00 PM
mrcleanr6's Avatar
the uc-35 is their main clear that most people use. the ufc is the flo clear. its a lower solids verion for flow coating.
Old 08-23-2005, 02:08 AM
more debt than brains
go with the uc 35 its great stuff... its all i use... put 3-4 nice coats on wet sand with 1000 grit then run two to three more wet coats on the car ( over reduce for flow coats its in the tech manual). and look out for the shine once buffed... incredable...... i like perfect it III for buffing seems to work very well its made by 3m.
jeff
HOK UFC35...drying problem, again theHIGHLANDER Body - Exterior 16 07-19-2010 05:56 PM
HOK Nova Orange Shakey Body - Exterior 4 06-02-2005 11:45 AM
HOK paint over PPG K36??? dh79 Body - Exterior 21 03-04-2005 01:51 PM
??? about HOK paint job Mag Body - Exterior 2 09-09-2004 03:28 PM
How much paint for HOK base/kandybase/klear? dh79 Body - Exterior 2 02-11-2004 01:26 PM
