Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - HOK kpc2f epoxy primer.. not adhering well?
Old 04-13-2005, 06:36 PM
BarryK's Avatar
BarryK BarryK is offline
You are probably in good shape!
Epoxy does not give maximum bite right away, the first 24 hours if you take a scraper you can probably scrape it off pretty easy after 48 hours you may chip a few spots after a couple of days as the epoxy cures is when you start getting adhesion to the point that it won't scrape off or not feather.
Now also keep in mine that cold metal will slow the above process down.
The above days I'm speaking of would be 70 Degrees or higher.
