Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - HOK kpc2f epoxy primer.. not adhering well?
Old 04-13-2005, 11:54 PM
baddbob baddbob is offline
I quit doing acid many years ago Metal prep type acid treatments caused me a lot of grief. A clean and textured surface is all the epoxy should need for good adhesion IMO. When you're done cleaning the metal surface you should be able to wipe a clean white towel with no discoloration showing on the towel.
